millzee
millzee's Avatar
06.08.2012, 04:13 AM
I've been trying to work out the best power system for the system and after a lot of thought I had decided on two set ups, 2x Neu 1527 1.5y 850kv motors to run on 8s/10s or a gasser. I was starting to think this hull will need a bigger prop than can fit on an outboard leg so to put an end to the thought process, I've purchased a rcmk s-520 evo g-2 twin cylinder gasoline engine http://www.google.com.au/url?sa=t&rc...x-XDjh_dMvV0mw that should do the job nicely. I'll update when I get the engine.
