JAILBIRD
06.13.2012, 05:47 PM
I am in the process of converting a few server power supplies also. I don't know what PS you are using, but on mine there is a bank of small pins, some of which need to be jumped to activate the PS. I was planning on just puting the switch in the circuit between 2 of the pins. I will be using a standard SPST switch from Radio Shack. There is very low voltage on the pins.
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
06.13.2012, 06:44 PM
I have converted a couple of server PSUs and neither of them had switches. I would have just put a switch on the jumper I made except the fan runs as soon as you plug it in. So what I did was open up the case and cut the black AC input wire right after the plug and put a switch I stole from a fried ATX power supply in line. Then I cut out a little square in the back of the PSU and wedged the switch in there such that it couldn't move once the case was put back together.
This would probably work fine for you.
http://www.radioshack.com/product/in...ductId=2062523
http://www.radioshack.com/product/in...ductId=2062485
Just find a switch that is rated for 125VAC and 10 amps or better. The circuit breaker on your house 125VAC is probably only 15a or 20a, so getting a switch rated higher than that would be pointless.
Good luck! Make sure it isn't plugged in when you're working on it lol.
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
