sikeston34m
sikeston34m's Avatar
06.15.2012, 05:32 PM
OK, I stand corrected and have made adjustments.
brian015
brian015's Avatar
06.15.2012, 05:41 PM
You may want to further clarify that it is for the 1580kv version rather than saying it works with all kv ratings - just so you don't have to deal with any unhappy customers.
sikeston34m
06.15.2012, 05:44 PM
That statement is true.
Kv rating of any motor is not established by the rotor.
Kv rating is a result of the number of turns in the wind.
brian015
brian015's Avatar
06.15.2012, 11:08 PM
OK - but Castle has only made a 1717 with two kv ratings (1580 and 1650) - does it work with both of those motors?
The answer that has been established by the President of Castle Creations in this thread is "NO".
I don't know why you are trying to respond to me with some technicality - the bottom line is that if someone buys this for the 1650kv version, they're not going to be very happy. And your eBay ad is still misleading.
Pdelcast
Pdelcast's Avatar
06.18.2012, 09:33 PM
That's not exactly true.
The kV is inversely proportional to flux in the air gap, so weaker magnets = higher kV, stronger magnets = lower kV.
And by the same token, smaller air gap = higher air gap flux = lower kV, and larger air gap = lower air gap flux = high kV
Patrick del Castillo
President, Principle Engineer
Pdelcast
Pdelcast's Avatar
06.18.2012, 09:35 PM
And the new 1717 is completely different -- different stator, different rotor diameter, etc.
