coolhandcountry
coolhandcountry's Avatar
04.03.2006, 11:05 AM
I thought a lot of the 2 pole motors took like 15 degrees and the 4 poles motors took 30 degrees. The bk is set a t 15 from factory.
Peace!
Country
Help support the
Rc-Monster
Buy here
MetalMan
MetalMan's Avatar
04.03.2006, 08:47 PM
From the factory, it is set on "Automatic". It should run fine if you set it at 5 degrees.
bigair78
04.03.2006, 10:03 PM
And 5 degrees will give me more top end?
MetalMan
MetalMan's Avatar
04.03.2006, 10:56 PM
It shouldn't do much. That is just a good amount of timing to start with. However, you could play around with the timing, up to 15 degrees, and check the motor temps along the way.
