07.14.2012, 12:25 AM
Nope, the Rc-M revo adapter has an 8mm bore for 8mm pinion shafts.
What you would do if you want to use a revo shaft is simply get a set screw to use instead of the pin, or dremel the pin portion off.
But, if you are fabbing in a center diff dog bones and cups are the way to go. There are so many shafts available, you should be able to find a combination that works.
07.14.2012, 12:31 AM
for instance I used an lst center cvd and a hyper 8.5 front shaft to put a center diff in the last e-maxx I built.
I needed around a 100mm shaft, so I got into the r/c section of ebay and just searched 100mm. If nothing matched then I search 99mm, then 101mm. (you usually have a few mm's to play with)
I always end up finding a shaft that will work. If you absolutely can't find a shaft Rc-Monster Mike can make custom length shafts.
