Bmr4life
07.30.2012, 09:42 AM
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 25
Total Voltage: 11.10
Motor KV: 2650
Tire Diameter (inches): 4.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.0035
Spur/Pinion Ratio: 1.84 : 1
Total Ratio: 5.98 : 1
Tire Circumference (inches): 14.14 inches (359.08 mm)
Rollout: 2.36:1
Total Motor Speed: 29415 RPM
Vehicle Speed: 65.85 mph (105.78 km/h)
Effective KV Value: 2650
KT constant: 0.51 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
07.30.2012, 09:55 AM
The only thing that looks a little odd is the tire size. Looks like buggy tires size-wise. And the pinion tooth count is rather high. Other than that, everything looks ok. Since you other vehicle is pretty close speed-wise, it has to be something to do with this vehicle somewhere...
Bmr4life
07.30.2012, 10:15 AM
Yeah, its running buggy wheels and the pinion is high in hopes of 40mph on 2s.
Here's a pic with the 2s battery mounted. Its an older max amps 4200mah pack good for 84 amps. The 3s pack I used was a lot larger, 5000mah 25c turnigy pack.
nastety92
07.30.2012, 10:26 AM
Have you tried another 2s battery? What are the speeds on 3s?
Tamiya TRF801Xt-e
Bmr4life
07.30.2012, 10:34 AM
Originally Posted by Bmr4life View Post
Calculator says it should go ~44mph on 2s and ~66mph on 3s.
My actual speeds are 28mph and 43mph.
The performance of the batteries are consistent
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
07.31.2012, 11:09 AM
are you unloading on any of your diffs? I'm thinking maybe the center diff is a little loose.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Bmr4life
07.31.2012, 11:11 AM
I had the buggy apart last night and the diff feels tight. I don't know what weight fluid is in it but its definitely not thin. Also, it pops strong wing slapping wheelies.
Bmr4life
08.10.2012, 04:40 PM
I'm an idiot. I didn't have the esc retrained to my dx3. I used the kvm meter and it showed two motors not producing their defined kv. I then tried another radio and rx (a traxxas at that) and they both were just over their stated kv. Retrained the esc to the radio and with the current setup the calculator says I should be doing 56mph and I'm getting 52mph. I'll take that.
But yeah, I'm a bonehead for nothing thinking of this in the first place. I do like the kvm meter though.
chrismechanic
08.12.2012, 09:51 AM
simple...you have to deduct 10% loss in the efficency...
it says you will be doing 56...but its actually 52.
10% of 50mph = 5mph, there is your missing number...
well your loss is only 4 mph...
chris
Bmr4life
08.12.2012, 10:39 AM
chris
That wasn't the problem chris.
