zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.16.2012, 11:02 PM
Yeah we know Bondo.
mistercrash, the only graph about 300 you are thinking about is cell level capacity vs. kWh throughput... so after 300kWh have been cycled through the cell, it is at 80% capacity. That is ALOT of energy throughput.
It looks like my cell I bought is on the bottom of the cell capacity range at roughly 4.36Ah, range is 4.3 - 4.5Ah.... maybe the rejects of less than 4.4Ah are sent to resellers in China?
zeropointbug
Z-Pinch racer
10.16.2012, 11:36 PM
I am finding this thing doesn't have a very linear cell IR, seems to hold a narrow voltage range under load regardless of discharge current. Report back tomorrow for heated discharge test, cell temp will be 170 F.
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
10.17.2012, 11:47 AM
Yeah that's what I thought, I didn't understand the graph correctly
No brain, no headaches.
zeropointbug
Z-Pinch racer
10.20.2012, 12:43 PM
Dsch# 145
Cell IR reporting 1mOhm (cell temp 126F) CHARGE
DISCHARGE
Cell voltage: 3.447 (discharged a bit to get rid of top charge~99%)
Cell voltage under load: 3.089v. (after 30 secs of discharge
Discharge time: 1:57
zeropointbug
Z-Pinch racer
10.20.2012, 07:24 PM
Forgot to post the cell temp at start of discharge: 158F
Cell after discharge: ~170F
zeropointbug
Z-Pinch racer
10.21.2012, 08:11 PM
FROZEN CELL TEST
Cell temperature: -26 C (-14 F.)
Cell voltage before discharge @ -26 C: 3.456v
Discharge time: 1:56 secs (not 100% DOD, ~70% DOD)
Cell voltage with the 16ft of booster cable (6awg.): 2.02volts
Cell voltage at end of discharge: 2.86volts
Cell temp end discharge: ~10 C (50 F)
Quite a difference in start temp and end temp, at sub zero temperatures the cell is dissipating much more energy as heat... as you can see in the voltage drop.
zeropointbug
Z-Pinch racer
10.22.2012, 08:36 PM
Dsch#165 IR 2mOhm
4340mah
zeropointbug
Z-Pinch racer
10.23.2012, 11:50 AM
Any ideas for abusing this cell?
