WheelMan
Do Epic Sh!t
WheelMan's Avatar
11.14.2012, 09:54 AM
Originally Posted by Blazerss View Post
Thanks Wheelman. I could actually adjust the part a little bit from the stock Proline piece and give myself more travel in the upper or lower spring, but I just made exact copies. Figured Proline probably came up with a decent setup since they are about the best shocks you can get for the maxx, at least it's all I will run when I do run.
You've got a point there Its what they do, so I'm sure they designed them the way they did for a reason.
Either way, your alloy versions are very cool!
-Travis
Adults are just kids, with money.
Common sense, is not so common.
