11.27.2012, 11:31 PM
Solder connection, either on battery to esc, or esc to motor. Do you run 2x3s? Have you ever swapped out your series connector to rule it out?
Something is getting hot quickly and failing... feel connections separately for heat when this happens...
11.27.2012, 11:35 PM
Deans plugs? I suspect a solder joint, or possibly a bad plug on the series connector...
