Robl45
12.31.2012, 09:08 PM
Originally Posted by brainanator View Post
Have you ever screwed a screw that had dried loctite on it? It makes it more sticky, kind of acts like a lock nut. I would try what KMN said. Let some loctite dry on the hex or the nut, or even with them screwed together. Get some loctite dried up on the threads and give it a shot. If it doesn't work, you're not out any money, if it does, great!
no, I never tried it, thats why I was asking. I will give that a shot, nothing to lose. the nuts are real thin so just get some on the hex threads and let them dry?
KMN
KMN's Avatar
12.31.2012, 11:48 PM
I've had the best luck just letting it dry on the hubs, versus getting it on the nuts and letting those dry.....
Integy, as bad as they are, and I do not even recommend their nuts, is bad. I've had Integy 17mm's that were knurled and O-ringed strip out Kyosho and Hot Bodies hubs, even properly applied. They galled the aluminum, removed the anno, and stripped out the hubs. Your best bet is to let the loctite dry first, and then put the nut on. It's the best way I've found, but you have to re-apply with most hubs as they are fine thread. I usually just put a drop on the day(or month) before I run, and tighten the wheel nuts up. MAKE SURE they're properly threaded on, and give the loctite a chance to dry. It works, trust me.
If you have the funds, talk to King Headz. They make 23MM, and can make you what you want. Reverse knurled nuts for the left side, if they don't already.
Big House
Big House's Avatar
01.04.2013, 12:20 AM
I had the problem with my GTP. Ended it by using mild 3m spray adhesive on the threads. I dries tacky and doesn't allow the nut to spin off.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
