Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Emaxx Derek
01.11.2013, 12:44 PM
Thank you for your response. I emailed Mike and asked him about the drive shafts. I will in the mean time look into your suggestions.
I'm cool with the DIY part of it all....I seem to work on my MT more than run it anyway :) Labor of love....
Thank you for the information about the non-symetrical part...I'll flip it around tonight and see how it fits.
I went with the 58t spur and 12t pinon because I read that is what Mike suggested in another post for an emaxx. At this point I think I'd rather switch to a different spur than cut my chassis...My concern with cutting the chassis is that I might not have the mounting holes if I ever want to install the stock transmission again.
Derek
01.13.2013, 08:09 AM
I'm in your thread now. Did you have the center piece of the cd mount upside down? The flat part goes down...
Are you running traxxas diffs in the front and rear end? That would mean you can only really use dog bones, most center cvd's are for an 8mm pinion shaft.
I'll take a look at both my center diff maxxes and report back what I used.
Edit- this maxx> http://rc-monster.com/forum/showthre...&highlight=pif uses an LST center cvd in front, and a ofna hyper 8.5 rear dog bone in back.
My cybermaxx uses the FLM rear dog bone that came with the FLM chassis in the rear, and I believe a savage front dog bone up front.
Also like neil said, mod1 46 tooth spurs are a better fit and require minimum trimming of the chassis. In my cybermaxx I was able to trim in between mount holes, so I could still mount a transmission if I ever wanted to.
Are you using the 3906 or 3905 FLM chassis?
