01.11.2013, 01:32 PM
Hopefully thomas or patrick will see this thread and revert shortly... they did while I was posting...
Looks like Castle's hands are tied by HPI.
Thomas - Did HPI block the ability to downgrade to the old version?
Thomas Porfert
Thomas Porfert's Avatar
01.11.2013, 01:53 PM
I'm not sure on the specifics with this update/ESC. If they found/thought there was a problem with a previous version of firmware, they can tell us not to allow you to roll back to an older firmware.
We can even go so far as to completely lock out setting changes on the ESC; so if we find an there's something seriously wrong with an old firmware version, we will lock out the use of the old firmware on the new Castle Link software.
Basically all of the settings are grayed out and can't be adjusted. Then updating the firmware to the new version will remove the problematic firmware version on the list. This is a very extreme and rare situation that we only use it if a firmware version is causing damage to the hardware.
Thomas Porfert
Tech Support
