WheelMan
Do Epic Sh!t
WheelMan's Avatar
09.04.2013, 02:13 PM
1st test fit of the quad cab body! (frame is a little short, maybe?)
Frame rails, bolted together, ready for the guillotine
Felt a slight amount of guilt for chopping such a pretty set of frame rails in half, but I got over it quickly
The frame rail extension, and new transmission/transfer case placement with some custom mounts I started making
Left side trans mount all finished
Right side trans mount done as well
Driveshafts cut to length and installed
-Travis
Adults are just kids, with money.
Common sense, is not so common.
WheelMan
Do Epic Sh!t
WheelMan's Avatar
09.04.2013, 02:14 PM
And the 1st test fit of the full Quad Cab & Bed on the freshly extended chassis! The body is just sitting on it with some blocks holding it in place for height (didn't have any body mounts made at this point)
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
09.04.2013, 02:15 PM
1st set of photos outside!
Made some additional frame extension pieces to stiffen up the whole area
Then of course came the spare wheel & tire, side step bars, and front tube bumper
He also sent a 2nd body he wanted to use with the truck as well
Spare wheel & tire mounted in the bed of the 2nd body
Then I finally started making some mounts to bolt the body on using the stock counter bored holes in the sides of the bodies
Rear body mounts
Bed mounts
Front body mounts
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
09.04.2013, 02:16 PM
I had to make some custom little mounts for the side step bars as well
Modified my stiffener pieces to get the side step bars up where they needed to be
Worked out perfectly to utilize the front 4-Link mounting blocks to bolt up the front ends of the side step bars
And of course my custom mounts for the rear ends of the side step bars
Underneath shot with both sides done
All body mounts, side step bars, etc, done
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
09.04.2013, 02:17 PM
Then of course the front bumper
I drilled and tapped some holes in the brush guard from the 2nd (red) body to mount the steel tube bumper to it
Then I cut the center of the tube bumper out (didn't work for what we wanted, it was made to fit a "stock" TF2 chassis)
And bolted the two together
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
09.04.2013, 02:18 PM
With all the little custom parts I made for it from just bare aluminum, some painting was definitely in order
All 4 body mounts painted and installed
Frame rail extension painted up!
And installed (looks much better)
Also painted the aluminum spacers I used to extend the links in the 4-Link suspension (spacers were just to fine tune the length of the suspension, to get it exactly where it needed to be, and to get the axles leveled out)
-Travis
WheelMan
Do Epic Sh!t
WheelMan's Avatar
The fender flares on the 2nd body needed some fixing up, so I gave them a little attention
Some dremel work on the back side to make them fit the body better, and some sanding for new paint
New paint
And they fit much better
-Travis
