pinkpanda3310
pinkpanda3310's Avatar
09.08.2013, 08:29 AM
So my laziness is reaching new levels. The last time I ran the car a small stone jammed under the (plastic) spur gear and wore a groove in all the teeth. The gear mesh was binding a little as a result. Of course, I did absolutely nothing to fix it
On top of that, I kind of temporary mounted the body because I wasn't sure how tippy it was going to be. As a result one of the R clips fell out on the first and only run with the body on. I should have spent the afternoon fixing everything properly since it seemed a success but instead I dropped it in the garage and walked away
BUT..! to make up for my downfalls I did get some video for you guy's My daughter was the person in charge of media coverage. I'm sorry I can't work out the embed code anymore so you'll have to use the link.
https://www.youtube.com/watch?v=LOHc...LAXzleSPoXMd2w
Oh yeh, and the front right wheel only had a strip of tire on the inside edge of the rim.
