rcs2022
11.01.2013, 05:14 AM
Did pry it open at last, its not glued, but the thermal paste as I assume needs a little pull to seperate; not too much. And below are some pics, seems the Mosfets (I think this is what they are called; not sure) are partially burned; there are a lot of them....
Got the capacitors also out of the way. One side the thermal paste is on a mesh or tape, the other side is on the black thingys (mosfets) directly.
I don't think the capacitors were fried, but the mosfets caused the capacitors to get burned or whatever got them in this state.
