01.03.2015, 01:57 PM
So... Time for a little update on the project...
The car arrived back in NJ in the middle of Nov and since then I'm been tearing it apart and putting it back together again. There are a few things that needed to be completed in order for me to register the car in NJ (It's already registered and Titled in Montana) - The main things were fitting a parking brake and wiring the dash.
Along the way though I found that a few things weren't as fully functional and needed attention. First up was the cooling system - The car runs two small radiators in the size pods with fans on the back to help draw air through. Unfortunately on night one most of the coolant ended up on the garage floor! The culprit turned out to be several pipe insert bore reducers that were used to reduce the pipe size from 1.5" to 1.25" - easy enough fix to buy some actual pipes that reduced from 1.5" to 1.25".
Whilst I was at it I bought some bendable metal piping to enable me to route the pipe away from the serpentine belt where it was rubbing.
The pods themselves are fiber glass bolted onto the frame. I wanted to add some stiffening to help support the pods so cut up some 1/8" aluminum plate to make inserts the shape of the pod underneath the radiators.
Lastly I added some honeycomb radiator protector inserts...
