florianz
02.20.2016, 07:42 AM
excellent pics thanks! nude pics ei leik...
I wonder if the different looks mean different technique in building a brushless motor; or if it's just a cheaper way of building. Boths TP and chinese motor are D-wind, all MBP-motors are y-wind, so I will set timing on 7-15 deg., the D-wind should get timing up to approx 7 deg.
he TP are not an Aveox or Neu motor, but fairly good performers, you can tell from the details, I would say. The performance and torque of the small TP is at least on a similar level as my Tenshock x802l (which I like quite a lot). As soon as the wheather gets better, I will have to compare these motors!!!
What's really interesting is that these 3670 motors are (probably) performing on a level like a 4074 sized motor. In the early days, remember, we just 3670-sized brushless motors (and TV was b/w...).
florianz
03.04.2016, 12:07 PM
so I have got some pics of the MBP-motor.
--rotor/magnet is a bit longer then the one in the smal TP Motor
--coils look different then in the TP
--diameter of rotor/magnet is approx. 19mm
--overall quality is flawless
Had a few batteries with both motors, in soft sand, not on the track; but so far, good stuff. More to say after some tests on the track.
At least an alternative to the mainstream products, and I don't say that cc-motors aren't good, but the kv-choice is a bit poor (like 17-1800kv).
If anyone could post some pics of the poseidon motors, for comparison?
