bdebde
That's All Folks!
bdebde's Avatar
04.04.2016, 12:18 AM
Being that many motor manufacturers have statements like this in their manuals "Never apply full throttle if the motor is not installed. Due to the extremely high RPMs without load, the motor can get damaged.", I have never used the torque control feature.
Dr_T
Dr_T's Avatar
04.05.2016, 03:33 PM
As long as "no-load kv" x applied Voltage does not exceed the motor's max RPM, revving unloaded for a bit shouldn't cause any problems, right?
Pdelcast
Pdelcast's Avatar
04.07.2016, 03:15 PM
That's correct.
And you can always run the Kv test with a lower voltage too... it will still work correctly.
So, if the application is for 4S, you can run the Kv test with 2S if you are worried about overspeeding the rotor.
A lot of cheapy motors out there are skimping on rotor materials -- so the concern is not unjustified.
Patrick
Patrick del Castillo
President, Principle Engineer
