Overdriven
Destroyer of Tires
Overdriven's Avatar
05.29.2016, 04:48 PM
Originally Posted by The Dude View Post
look nice, just one thing, can we fill the diff w/ silicon oil ??
If you did it would just leak out of the diff locking pin holes. The locking pins go threw the diff cup and into the spider gear on that side when the locker is engaged. So you basically have to choose between grease filled diff and locked diff. I think I'll stick with silicone oil filled sealed diffs, I'm sure I could get a pretty damn good compromise with the right weight oil that nobody would really notice the difference.
The Dude
No Way....
The Dude's Avatar
05.30.2016, 01:02 AM
I'm not sure
look a this pics
it seems to be sealed diff
crazyjr
crazyjr's Avatar
06.20.2016, 10:35 AM
I'm not sure
look a this pics
If that big O ring goes behind the side gear with the pins, then it's possible
Edit:, just looked at the exploded view, that large seal goes behind the pined side gear of the diff
http://www.arrma-rc.com/pdf/exploded-views/AR106009.pdf
Page 4 shows the seal and where it goes
