brainanator
brainanator's Avatar
02.16.2017, 01:23 PM
The big Castle BEC PRO has the same arbitrary voltage set points for some reason, while the standard BEC allows you to set it to whatever voltage you want in 0.1V increments. Quite annoying if you ask me.
Pdelcast
Pdelcast's Avatar
02.16.2017, 05:21 PM
Sorry guys, it's a hardware limitation in the controllers. For the BEC, we can set arbitrary output voltage because we are using a DAC and current mirror to set the output voltage.
We don't have an additional DAC available for the X controllers, so the adjustments are limited to a 2 bit setting.
Patrick
Patrick del Castillo
President, Principle Engineer
whitrzac
Can't catch this...
whitrzac's Avatar
02.18.2017, 12:12 AM
Patrick
Is it possible to add something between 6v and 7.5v?
I would settle for 6.5 and 7v...
