At 24V the etamax of this new castle is calculated at 95.3%, this is HUGE, and one of the best I saw until now ! Really cool. What is the real wolrd max eff of this motor ?
Around 90% efficiency max, real world.
Patrick del Castillo
President, Principle Engineer
OK. A so small difference is surprising me because, with fresh measures, on my motor the difference is about +30% no load current between 16V (3.75A) and 24V (almost 5A). The result is almost twice the power from 40Krpm to 60Krpm (60W to 120W) ! Thx for the informations about your new motor.
That's because of the thinner, more resistive laminations. The delta in IO is much smaller with RPM.
Thanks!
OK ! thx. That makes sense. So my motor is almost just a heat generator, althought I'm not complaining about the real performance level, but when you add the high efficiency, low temp et sensored mode of this new castle motor... I'm just wondering how resistant to dirt/bad treatment this motor could be when compared to the old unsensored one, only time would tell ?
