maxxximatoze
08.21.2018, 06:10 AM
While true, there are also instances when active freewheeling reduces efficiency significantly.
Cryodrive is more sophisticated than simple AFW, and results in efficiency gains across the board.
OK, it seems to be a very cool feature (in every senses of th word) ! What do you mean "instances when active freewheeling reduces efficiency significantly" ? Do you know if the hardware in the MMX can be compatible with this new software feature ? Tia.
Pdelcast
Pdelcast's Avatar
08.21.2018, 06:15 AM
I mean that in some circumstances, AFW reduces the system efficiency vrs passive freewheeling.
I don't know offhand if the MMX will support Cryodrive. Sorry, I'm stuck in Shanghai at the airport waiting for a six hour delay flight.
Patrick del Castillo
President, Principle Engineer
maxxximatoze
08.21.2018, 06:20 AM
6 hours ! sorry for you, hope there is a bar not too far to drink some beers ;)
