glitching ??
gmo
glitching ?? - 04.12.2006, 06:19 PM
hey guys, i just got my sspeed mod installed and was going to run it. but have a weird problem, while turned on for/rev is ok but the truck glitches like crazy when im handling it .like when i turn it upside down itll start throttle jerking, and even the steering servo will react on its own.i unplugged the servo and she still jumps, everythings tight, should i just try reciever locations or is this a common novak issue? :002: any feedback would be helpful.....thnx gmo...
HotnCold
HotnCold's Avatar
04.12.2006, 06:27 PM
check to make sure that your receiver antenna wire is not near metal - if so - isolate with a piece of fuel tubing to keep wire from metal.... Thats a start -
Hows that "Hope and Change" working out for Ya???
gmo
04.12.2006, 06:41 PM
yeah, its not. i have the stock chassis..
HotnCold
HotnCold's Avatar
04.13.2006, 04:48 AM
i've never heard of the novaks doing this - i guess changing locations on the receiver wouldnt hurt. It only does this when you are holding it - not when it is on the ground or running on the ground. Weird to say the least...
Gustav
Gustav's Avatar
04.13.2006, 05:13 AM
You must be very conductive,you could try wearing rubber gloves.
coolhandcountry
coolhandcountry's Avatar
04.13.2006, 06:46 AM
If it don't do it while the rc is on the ground I wouldn't worry about it.
Peace!
Country
Help support the
Rc-Monster
Buy here
g man
04.13.2006, 07:03 AM
are you running a ubec pack
coolhandcountry
04.13.2006, 07:22 AM
I run the ubec yes. I do have a problem some time if to close to the rc with the radio.
Peace!
Country
Help support the
Rc-Monster
Buy here
g man
04.13.2006, 07:36 AM
just thinking if the battries are low that would also cause it to glitch
g man
04.13.2006, 07:38 AM
or the ubec i low
