sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.16.2006, 06:08 PM
they appear to be just aluminum...but who can tell....I agree with you....with that being so thin...it's prone to failing...here is a little history about how my Ultramaxxed gen II's failed......basicly it was from shifting from 1st to 2nd and back, while under power....and not letting off of the throttle.....this caused the failure in my case.......and that was on gears that had more pin surface contact......and with those appearing to be so thin in that area.....i see a problem ...since alot of the peeps run BL around here.
  Send a message via MSN to sjcrss
