GriffinRU
04.19.2006, 07:42 AM
Originally Posted by cspurlock
Stating the obvious, "guessing is not an accurate tool" of course it is not that is why it is called a guess. :007: Also, where did I base my statement off the motor not reaching a specific RPM in a Emaxx??:032: If you read my post you would see that I was not questioning the kv based off my guess, but instead off of the word of one of the R&D people that work at Novak. You can see I live in So Cal, so not too far fetched to believe that @ So Cal raceway(my home track) I might know a few people that work @ Novak seeing this is their home race track also. You believe whatever you want, but I will choose to believe a Novak R&D person over you.
Magnetic field is stronger in So Cal...
Artur
GriffinRU
04.19.2006, 08:14 AM
:mad:1
In general Kv number represents motors RPM @ given voltage with "0" timing.
Timing can change Kv number significantly and while most BL controllers allow you to change timing or adjust it automatically for you, Novak's ESC has this value fixed (possibly in 2 values). So as system it can perform poor, but on paper with correct timing and without load Kv=4400 can be guessed. Otherwise it is false advertisement and all Novak HV-Maxx systems can be re-called :)
Artur
