boss 302
05.14.2006, 08:43 PM
Originally Posted by squeeforever
Thats odd....Also, kinda heavy, don't ya think? It says 2.4lbs....
Dewalt says that their 36 volt cells way the same amount as 18 volt NiCD cells
05.14.2006, 09:35 PM
The A123 cells are able to charge in less than 5 minutes actually, but they (DeWalt) must not be taking advantage of that. Maybe it reducing the cell life to charge at a high rate all the time.
I'm hoping they will be 3Ah cells. 36v will mean I'll be able to make two 18v (5s) packs from one module. 2.4lbs for a 36v pack means 1.2lbs for one 18v pack.
About the weight: a sub-C cell weighs 65g. An A123 M1 cell weighs 99g. It takes three sub-C cells (195g) to equal the voltage/capacity of one M1 cell - as long as the M1 cells are ~3Ah each, otherwise two in parallel would be needed and would weigh more...
