MetalMan
MetalMan's Avatar
05.17.2006, 08:43 AM
Welcome!
The ideal motor and ESC for your application depends on how much you can spend. You could go with a Quark Monster 125amp ESC ($280) and a Lehner 1940 motor ($285), or you could use a less expensive setup.
Philyon
05.17.2006, 10:15 AM
Thanks for your reply.
Your setup is a little expensive for me. I thought to put a Lehner 3100 on it with a less expensive ESC, but which one ?
And about the pinion gear, how much tooth must I choose ?
Thanks
