coolhandcountry
coolhandcountry's Avatar
05.30.2006, 10:05 AM
I think the carbon straps will fit but need moding to fit the flm. I have seen a few make a sheild for the batts. I never accually worried about it. Some bodies you find go lower than others so if you put the body mounts in the right place you can cover most of the batts up. The flm is tough though. I never had a problem one with bending or twisting. The gmaxx is tough but alot lighter as well. The gmaxx aluminum is same weight as stock. The extension may add a few grams.
Peace!
Country
Help support the
Rc-Monster
Buy here
