GriffinRU
06.22.2006, 03:05 PM
That doesn't look so good... Are you sure the front diff was shimmed properly?
Yes, it was shimmed. Maybe a little bit less tight then stock.
And I did couple light runs to break-in differential.
You sure it didn't get loose from the diff?
is this because of the too hard brakes?
I do not know, really. I do not even recall when that happens; just notice noise and erratic behavior of the front end.
Maybe it was over hardened from manufacture or just a faulty ring gear. There is no a single scratch on pinion gear.
Does anybody know where to get ring gear? Differential itself is in top condition.
Artur
Red350DropTop
08.25.2006, 11:04 PM
Hello guys, and sorry to drag this from the bottom of the pile but I remembered this post well.
Looks like Novak has revised their KV rating of the HV-Maxx motor.
http://teamnovak.com/products/brushl..._chart_web.gif
3100KV it is.
