06.24.2006, 02:52 PM
Yeah, I like their cases because they are easy to mount, but after looking at the thickness of the aluminum, it is really too thin and doesn't have enough thermal mass. Plus, the fins that do exist are really too small. According to their specs of being able to run up to 6s/18cells (~22v nominal) and 125A continuous, that is 2750 watts. At 90% controller efficiency, that's still 275 watts being dissipated on the controller, which is WAYY too much for that little heatsink. To be honest, the heat sink needed for that kind of dissipation would be quite large, even with fan cooling. Like I said, adding more thermal mass would be nice to pull the heat from the ESC, and then adding more/taller fins to dissipate the heat. Don't forget to use thermal compoung between the ESC heatsink and whatever you add for efficient thermal conductivity. I actually lightly sanded the back of the ESC to get rid of a lot of the texture and then used thermal epoxy (Arctic Silver) to secure the ESC to the added heatsink.
squeeforever
squeeforever's Avatar
06.24.2006, 02:55 PM
Brian, do you have a picture of what you did?
06.24.2006, 03:14 PM
Not yet. My camera was dropped and I have to fiddle with it to get it to work. :mad:1
I'll try to get a pic of it later. The thermal adhesive I used is this: http://www.arcticsilver.com/arctic_s...l_adhesive.htm
The version I used has traces of silver in it (hence the name) so it is advisable to make sure none squishes across connections when you compress the heatsinks together. They have totally non-conductive stuff, but I didn't have any of that. You can use thermal tape too, but it doesn't work quite as good.
Whatever heatsink is used, make sure that both surfaces (the ESC and the added one) are smooth and flat for best contact and thermal transfer. Like I said, I sanded the back of the ESC with fine paper, and then I almost polished the piece of aluminum I used for the added heatsink.
06.24.2006, 08:41 PM
OK, a couple pictures of the heatsink:
I'll probably replace those shallow PC memory heatsinks with something a little bigger, but for now, it all works quite well.
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
06.24.2006, 10:58 PM
The flat bottom of the heat sink offers the best surface area for heat transfer and it looks like you nailed it, I'd give it a few runs before I change anything. At most you might need a fan.
Very clean I like it.
I was going to swiss cheese my heat sink but the only problem is I don't know how much I can drill out before it is too much and I start overheating.
I think I'm going to make a few runs in the heat before I start fixing things that aren't broke.
Never fight an ugly man..... he has nothing to loose
06.24.2006, 11:50 PM
Like I said, the way I currently have it reduced temps by 12 degrees after 15 minutes of bashing around the yard. I am going to remove those small PC memory heatsinks and replace them with two of these, again mounted with thermal epoxy. That should reduce temps even more. I hate using a fan because it adds wiring complexity (albeit small) and it's just one more thing to break or wear out, which is especially bad if you are counting on the fan to keep things cool. I'd rather keep it passive if at all possible and arrange the fins so airflow runs through them. Swiss-cheesing the sink should work as well too - I'd use holes no larger than 1/8" and have 1/8" spaces between them. The idea is to create as much exposed surface area as possible while keeping enough mass in between.
squeeforever
06.24.2006, 11:57 PM
Cutting holes in the top and adding a fan over them would be a good option...
Sylvester
Sylvester's Avatar
06.25.2006, 10:59 AM
He just said he doesnt like fans squee:p Alot of people think a fan is a type of "bandaid"
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
squeeforever
06.25.2006, 11:06 AM
Sylvester, I don't particularly like them either. I was just saying. Its a option for some people.
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
06.25.2006, 12:01 PM
how is a fan a "bandaid"...just think...if your PC didn't have any fans to help keep it cool...you wouldn't be able to use your pc with out it overheating...let alone getting on this forum...I see fans an neccessity in some cases, but a personal preferance on others.....my thought is...a little extra airflow on the controller can't hurt it at all.
  Send a message via MSN to sjcrss
Sylvester
Sylvester's Avatar
06.25.2006, 01:38 PM
Yea, but like brian said, on an rc you'd have to replace them after a while, it can be just another thing to break, takes away some runtime, and adds complexity to the wiring, i dont like them too much, thats why people use bigger heatsinks.
Losi 8ight e
Cartwheels
06.25.2006, 04:41 PM
Here is the heatsink I'm using right now. http://www.dealsonic.com/thera1ddrsdr.html . It works but does not fit that well. I've got the two heat sinks side by side runing long ways on the quark controller. They are not quite long enough and a little wide. I might order one more set and run them the other direction and cut the extra off. That way it would be a cleaner fit.
I'm a fan fan
smhertzog
smhertzog's Avatar
I'm a fan fan - 06.26.2006, 07:35 AM
Fans do have some good points.
I have a lipo setup in my mini lst and on a few occasions I forgot to unplug the battery. Once it drained the lipo battery to the point were I had to charge it as a NIMH battery till it got a charge in it because my charger wouldn't even charge it. I was waiting for it to go boom but it didn't, it also was never the same either and I have since pitched it. There is no misstaking wether or not my Emaxx is on, the little novak fans sound like a turbo spooling up which is kind of cool in itself. Just imagine ruining $280 worth of batteries just because you forgot to unplug your batteries.
As far as run time goes I havent noticed a difference, there is a difference it is using a fraction of an amp but its not noticable.
As far as wiring complexity one more pair of wires isnt that big of a deal.
Just my 2 cents, I never knew fans were taboo with so many people.
In the end to each his own i guess.
06.26.2006, 09:16 AM
I agree: to each his/her own.
BTW: A bright "power on" LED works as effectively, requires less current, less space, and is not mechanical. ;)
no mods
06.04.2007, 10:27 AM
so what was the verdict? did you ever completely rid your thermaling issue? i have the same problem. i just wish i didn't have to void my warentee to pick up quarks slack so to speak. i run mikes heat sink with everything but fans and i still only get about 5-7 min befor play time is ovr
