Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
06.26.2006, 03:28 PM
If it's strictly on-road and 2wd and inbetween 1/10th and 1/18th, why not a 1/12th pan car? Those things are simply r o c k e t s when matched with brushless and 6 cells.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
Batfish
Batfish's Avatar
06.26.2006, 04:07 PM
1/12th scale pan cars are indeed fast. I actually have a SpeedMerchant Rev.3 that I'd be willing to sell - especially with the purpose of a good project :003:
They can be set up very firm and they are VERY easy to work on. Everything is essentially mounted to one CF plate (chassis) with a motor pod in the rear.
The only issue with these cars (when used outside of the carpet world) is usually ground clearance. My car, when set up to run on the carpet, has about 3-5mm of ground clearance. You could definitely set the car up for some speed runs on asphalt by putting new tires on and not cutting them down to normal running diameters.
I'd consider 3s or 4s lipo with a 380 motor and good speed controller. Should be able to get a good 2000mah (or larger) high-discharge lipo to fit the battery location, and Quark 60A controller with a 380c motor to fit in the little thing. That could absolutely fly. Just don't hit a pebble...or a crack in the road...or a spec of dust...at those speeds :003:
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
06.26.2006, 06:59 PM
Hmm, then maybe a dropped buggy might be a better solution for me. I plan to run primarily in parking lots and such where cracks, seams, and pebbles are a certainty. I don't want to send my vehicle careening into oblivion from hitting a tiny crack!
After looking at the Associated buggy, I don't particularly like the motor so far back. Won't it have a tendency to wheelie with the weight there? That's kinda why I was leaning more towards a Jato - that and both my LHS have tons of traxxas parts in stock. I won't totally discount the Associated one though - I think one place nearby has one for sale so I'll check it out.
Thanks for the suggestions!
Batfish
Batfish's Avatar
06.26.2006, 08:04 PM
The Associated B4 is one of the top two supported buggies for racing (the other being the Losi buggy), but if your local shop doesn't have much support for it you are likely better off with a different choice that your local shop DOES support.
Although the Jato does have the opportunity to mount the motor in front of the rear axle, that also cuts into the room you have to mount other items. Also, when I converted my Jato and raced other electric stadium trucks, I'm pretty sure the Jato was about 1 lb. heavier than the others. This has quite a bit to do with the extra weight of the transmission and aluminum chassis.
A 1/10th scale 2wd electric buggy will give you the smallest, lightest 2wd form to get you started, so that would be what I'd advise.
As I initially stated, though, your best bet is almost always to own things that your local shop supports. It will help out the shop owner and yourself at the same time.
Keep in mind that if you can't find it in your local shop, www.RC-Monster.com is just a click away and rcmonstermike@gmail.com will do everything he can to get you any parts you need! :003:
Joe
06.26.2006, 08:19 PM
Like I said, I won't discount the B4, but the motor positioning is the first thing I saw and didn't like. I'll also take a better look at my LHS, but they seem to be mostly stocked with HPI and Traxxas parts - I could have missed some stuff though.
And, I know full well where RCM is, where do you think I'll be getting the BL stuff from? :dft012: Sometimes it's just easier and faster to get the small stuff from a local shop - ordering stuff online won't let you pick up a broken part to have you up and running the same day.
Batfish
Batfish's Avatar
06.26.2006, 09:27 PM
Agreed - Like I said, always support your local shop. If you don't, they won't be in business when you need them.
:003:
Joe
06.26.2006, 11:31 PM
Batfish: I read in the Jato area where you did a Jato conversion. Got any pictures? Did you do the single speed conversion, and if so, does it allow you to use ESC brake and reverse?
JB3231
JB3231's Avatar
11.11.2006, 09:29 PM
I tried the B4 for an onroad basher with a Mamba Max 5700Kv and Lipo 3S. The motor placement does not work well. There is too much weight in the rear and it just wheelies at all speeds. I was getting 60+ mph out of mine but I could never just punch the throttle. I had to try and ease it up to top speed. Also the tower's get completely destroyed if you ever flip it over on concrete.
My next project, very similar to yours, will be something 4wd and have much more weight bias towards the front. I would recommend something like a 1/10th 4wd buggy with street tires. Maybe a Losi XXX.
Also the B4 with that much power will burn the tires up after 2 packs. Mine were completely bald after 2 runs in a parking lot.
Hope this helps since I just tried the same thing.
Mine:
2007 Grizzly 700 EPS EFI
Sons:
BL E-Maxx
4S MA 4000 Lipo/MM ESC
Feigao 9XL 22/54 gearing
Gmaxx single speed
Brushless Revo under construction
