Batfish
Batfish's Avatar
06.27.2006, 08:44 AM
Originally Posted by BrianG
Batfish: I read in the Jato area where you did a Jato conversion. Got any pictures? Did you do the single speed conversion, and if so, does it allow you to use ESC brake and reverse?
The Jato transmission has a one-way bearing in the first gear, which does not allow the use of reverse by default. I did not do the single speed conversion.
I originally ran the truck with a servo for the mechanical brakes. In the second configuration, I locked the transmission into second gear, which bypassed the one-way bearing in first gear and allowed me to use the ESC for braking. In the third (and final) configuration, I unlocked 2nd gear and added a servo again for mechanical brakes.
If you want to do some custom work inside the transmission, I'm sure you can get it set up to use the ESC for braking.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
