DMCfirestar500
06.29.2006, 05:47 PM
Well, I finally got around to finishing up the buggy. I bult the 2 packs each in identical 5s1p configuration. They are set up like this: 111= so theres 3 cells wired sxs then 2 more wired sxs perpendicular to the other 3. This allowed for best weight dispersment and the lowest cg possible.
I mounted the motor so the shaft is directly above the center diff spur and the back of the motor is near the back of the buggy . With my buggy having 2 chassis plates this made mounting everything extremely easy.
I'm charging the packs right now 1 at a time at 3 amps each not using the balancer as I havn't put taps on the packs yet.
I'll take some pics now of the buggy and packs and post them here, and hopefully some bashing vids later today.
