MetalMan
MetalMan's Avatar
06.30.2006, 11:06 AM
Planes need to run limited RPMs because of the propellors that they use. But, they can use gearboxes on the motors, so there's no reason why a plane can't have a motor spinning faster.
Are these motors with a kv of 500 outrunners or (standard) inrunners? Outrunners function differently, and work with a much lower RPM.
06.30.2006, 11:26 AM
Well, the reason I ask is I was thinking of doing a direct motor-to-diff drive using a lower rpm motor, but if they are still supposed to spin at such high rpms, then it wouldn't be a good idea. I was also thinking of using one of those inline planetary gear drives, but they are quite expensive. I was shooting for a semi-realistic car where the motor is in the front, followed by the "tranny". But, it looks like I'll still be using a spur/pinion arrangement.
06.30.2006, 11:27 AM
The ones I was looking at were from the Feigao charts, so I assume they are inrunner types.
