Hustler
Hustler's Avatar
07.04.2006, 03:51 PM
I am having problems with the stock part inside the differential that you connect the shafts to, meaning I am using the stock ones right now and not the cvd's or UE's. Only one shaft will connect properly with the screw (l-key head) with that part inside the differential. The other side will not connect properly (the hole doesnt allign and doesnt come far out of the bulk for me to connect the shaft properly with the screw).
I am not sure what exactly you call that part thats inside the differential. There are two, one is a lil big and other is smaller.
Hopefully, I made some sense explaining the situation. But it looks like the FLM bulks should connect fine with all the other stock parts..!!
