07.07.2006, 12:53 AM
Originally Posted by phidailo
Brian - there is slight play front to back. Also, something rattles when I shake the motor
Well, there will be a little play, but if there is too much, the rotor may slide forward while spinning, and then smack back again when it stops or decelerates (or vice versa).
I'd be more concerned about the rattling personally. I'd send it back to Mike before you try prying off the endbell unless he says it's OK to do so.
phidailo
07.07.2006, 01:25 AM
Thanks, the sound and rattle was coming from the slight play so I tapped the shaft forward a bit to stop it. I happen to damage the bearing cap in the process. Can I purchase this type of bearing separately? and if so where?
  Send a message via AIM to phidailo
07.07.2006, 01:31 AM
That, I can't say. I'm sure someone else will have the answer though...
phidailo
07.07.2006, 02:18 AM
Well the sound is still there after I plugged everything back up. No rattle since the shaft is in place now
07.07.2006, 02:36 AM
No rattle, but the sound is still there. Hmm, I don't know, but I suspect the bearings. I'd send Mike an email. If you want to replace them yourself, make sure you get bearings rated for high speeds.
On a side note; how hard was it to pop the endbell off? Not that I plan to do it just for giggles, but if ever I need to replace the bearings, I'd like to know what I'm in for. And, how hard was it to pop back on?
phidailo
07.07.2006, 03:30 AM
need a light tap on the shaft with a hammer and it came off and vice versa with putting it back on
