phidailo
07.07.2006, 01:25 AM
Thanks, the sound and rattle was coming from the slight play so I tapped the shaft forward a bit to stop it. I happen to damage the bearing cap in the process. Can I purchase this type of bearing separately? and if so where?
  Send a message via AIM to phidailo
07.07.2006, 01:31 AM
That, I can't say. I'm sure someone else will have the answer though...
phidailo
07.07.2006, 02:18 AM
Well the sound is still there after I plugged everything back up. No rattle since the shaft is in place now
07.07.2006, 02:36 AM
No rattle, but the sound is still there. Hmm, I don't know, but I suspect the bearings. I'd send Mike an email. If you want to replace them yourself, make sure you get bearings rated for high speeds.
On a side note; how hard was it to pop the endbell off? Not that I plan to do it just for giggles, but if ever I need to replace the bearings, I'd like to know what I'm in for. And, how hard was it to pop back on?
phidailo
07.07.2006, 03:30 AM
need a light tap on the shaft with a hammer and it came off and vice versa with putting it back on
