go4gold
mod emaxx
go4gold's Avatar
07.17.2006, 09:35 PM
The black jumper is for the internal bec. Jumper on=internal bec enabled and jumper off=not using internal bec. One other thing to check is the 2 pins that are sticking out after you remove the red jumper. Make sure they are not touching each other or something metal. Hope this helps some. I would also cheack all the connectionson the motor and esc
So many toys and so little time
