FLM Combo bulk question
Ozark-al
I wanna be like Mike
Ozark-al's Avatar
FLM Combo bulk question - 07.21.2006, 04:48 PM
I just recieved my combo bulks from Mike. They look sweet. I have 2 questions though. What size bearings do they take, and what are the holes for that are on the side by where the bulks attach to the chassis? Thanks.
My brushless maxx in the hands of my 6yr old son is... bad. My brushless maxx in my hands... even worse!!!!
squeeforever
squeeforever's Avatar
07.21.2006, 10:39 PM
I'm pretty sure the stock bearings will fit. As for "what are the hoels for that are on the side by where the bulks attach to the chassis", I think you mean thats where the input shaft goes??
Ozark-al
Ozark-al's Avatar
07.22.2006, 02:34 AM
I checked at my lhs and ordered some boka bearings
I think I got 4 6x16 and 4 10x 16. The stockers don't fit. The holes I am referring to are drilled on the side of the bulk (one each side) right past where the two screws that attach each side of the bulk to the chassis. They are at a right angle to the chassis screws and come from the side of the truck.
Serum
Serum's Avatar
07.22.2006, 03:40 AM
You need 8X16X5 bearings, pressuming you got the 1/8th bulks.
if you got the bulks for the stockers, the stock bearings fit.
squeeforever
07.22.2006, 02:02 PM
Yea, I assumed you got the Combos for the stock gears since it says combos in the top of the thread.
Ozark-al
Ozark-al's Avatar
07.23.2006, 06:00 PM
Could I of got the wrong bulks? The stock bearings do not fit. the O.D. of the bearings is not the same.
Mike.L
Mike.L's Avatar
07.23.2006, 10:19 PM
could those holes be for sealing the two halves together?
  Send a message via MSN to Mike.L
Ozark-al
Ozark-al's Avatar
07.24.2006, 01:15 AM
Kinda what I thought but they are right below where they attach to the chassis.
Mike.L
Mike.L's Avatar
07.24.2006, 11:16 AM
does the hole point to the other halve case? or somewhere different, are both front and rear halves the same?
Ozark-al
Ozark-al's Avatar
07.24.2006, 03:45 PM
Ok, I have talked to Mike, he said I got the hybrid bulks by mistake. Guess that answers the question about the bearings. I am going to wait and see after I have put the bulks together to see what the other holes are for.
thanks all
