tallyram
tallyram's Avatar
07.23.2006, 10:57 PM
i pm'd ChC and he said the problem with 6s is only with the 80a quark. i just ordered a 125b from mike, so we'll see if it handles the voltage! thanks for the help guys!
  Send a message via AIM to tallyram
07.23.2006, 11:11 PM
For what its worth, the 80B and 125B are probably essentially the same ESC and use the same FETs (which means they have the same working voltage) except the 125B uses more of them to handle the extra current, hence the longer packaging. Unfortunately, the FETs don't come off the heatsink easily (I know, I tried) to verify this. As long as you use the ESC properly and stay within it's rated voltage and current, Quark has to honor their warranty. If they say the 80 will handle 6s, then it should.
