07.28.2006, 10:26 PM
Wiring it is really simple - especially if you stick to 12v (you can wire a 12v regulator to provide more voltage).
- Run a small 20GA wire from + of your main battery to pin 1 (left) of the regulator.
- Run a small 20GA wire from pin 3 of the regulator to the + lead of your fan.
- Run a small 20GA wire from - of your main battery to pin 2 (center) of the regulator.
- Run a small 20GA wire from from pin 2 (center) of the regulator to the - lead of your fan.
Put a heatsink on the IC and use a thermal insulator pad. IIRC, the tab on the IC is common to the output pin and if it touches any negative lead, it will damage the IC.
I'd stick to the 12v fans as they will move more air and are far easier to find. You can use a fan from a computer video card, chipset fan, CPU, etc and those all use 12v.
Gustav
Gustav's Avatar
07.28.2006, 10:35 PM
Thanks Brian,i get it now.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
07.29.2006, 12:04 AM
Just a thought here... if you want to run two fans, you could just hook them up in series and they would each see 15V which would be perfect for a little voltage boost.
I have seen some pc cooling stuff that piggybacked two fans together... and I have thought of doing that just to get more airflow on my 12V fans.
07.29.2006, 12:11 AM
That is another solution as long as the voltage is 24v-30v. However if he wants something that will work with batteries below 24v (4s and 5s), then the regulator might be his best bet.
Gustav
Gustav's Avatar
07.29.2006, 12:55 AM
I'm been toying with the idea of using the venturi effect and doing away with fans altogether,i'm trying to figure out what ratio between input and output area of the tube i would need to tripple the air speed.If i could get a 60mph wind blowing over the thing every time it goes 20mph then i don't think there'd be much need for a fan.
Might have to be more like double the air velocity so the OUT isn't too small or the IN too big to be practical.dunno haven't figured it out yet,there's online calculators for it though.
Drag might be a problem though,as might ripping the body clean off at 50mph:005:
The problem with just cutting holes in the body is it opens out after it enters and the air slows down so we're not really getting all that much cooling at these relatively slow speeds,i think maybe what we need is a tube or tubes going to the areas we want cooling.
cabking
07.29.2006, 06:18 PM
Gustav, I recon a couple of ice cream cones through the windscreen could do the job.....they would have to be double scoop size obviously.....
That just leaves you to work out how much to bite off the end.......:004:
Ive always run my fans on 16-18 cells ( knowing sod all too :027: ) The one thing I am sure of now, is the neon ones seem to last consideably longer than the standard fans.......I plainly have no idea why this would be, just though id pass it on.
Gustav
Gustav's Avatar
07.29.2006, 07:03 PM
That sounds a bit technical,so far all i've got is a fairy liquid bottle jammed in the grill with a plastic pipe stuck to it,it's sure to catch on.
