I also took Sqee's advice and changed the gearing to 16/66. I Definitely see a difference with less heat in the motor and less heat on the speed control. :027:
Its still better than the original twin titans, and MUCH longer run times using a pair of 7.4V 6000mAH batteries.:018:
Sounds like an all around winner - much more run time - less heat - Good to hear...
