coolhandcountry
coolhandcountry's Avatar
08.05.2006, 07:33 AM
Originally Posted by BrianG
BTW: I weighed the Revo today:
Without the 14 cell GP3300 pack: 10.58lbs
With the cells: 8.47lbs
Not too bad.
Do you have the with and with out batteries weight backwards?
I would keep them cells if not. They remove weight more than add.
What about the evo packs? The have a good discharge rating.
Peace!
Country
Help support the
Rc-Monster
Buy here
08.05.2006, 04:26 PM
Actually no, the batteries I'm using are filled with helium and do reduce the weight. ;)
And now Squee's response post makes sense. I didn't catch that before. Doh!
Seriously: Yeah, the weights are reversed. Are these the EVO cells you are talking about? The GP3300 cells I'm currently using work perfectly fine if a bit heavy.
cemetery gates
08.05.2006, 04:45 PM
i think squee is talking about these http://www.flightpower.co.uk/
08.05.2006, 05:32 PM
Oh.
The only large single 5s pack that would fit length-wise is the 2500 pack, which is too low in capacity. Paralleling them would be too wide.
When I made the V2 Revo, I figured I would be able to find a decent battery solution to I was wrong. Oh well.
To summarize what I'm looking for:
- Weight = 500g-600g.
- Capacity = 4-6Ah.
- Continuous discharge of >= 80A.
- Fits into an area 6.25" long (160mm), by 2" wide (50.8mm) by 2" high (50.8mm). I remeasured the length just to be sure.
cemetery gates
08.05.2006, 08:00 PM
i think these will fit, but they are expensive! and :004: 30c discharge:004:
http://www.tanicpacks.com/catalog/pr...roducts_id=588
