Procharged5.0
Procharged5.0's Avatar
08.10.2006, 08:45 PM
I second Squee's opinion. It would be fine if you adapt a mechanical brake from the T-Maxx and program the brake to the disabled mode.
You do have a T-maxx don't you?
08.10.2006, 11:56 PM
You know, I saw that ESC a while back and remember being quite impressed with its construction. IMO, that is how an ESC is supposed to be built (from an electronics standpoint)! I like the aluminum layer in between each layer of PCBs/FETs and the ample heatsink. I bet that thing doesn't overheat or blow FETs! Too bad it's not apparently meant for vehicle use, unless you use mechanicial brakes.
