smhertzog
Breaker of all that is Stock
smhertzog's Avatar
08.17.2006, 07:47 AM
I have the ext gmaxx and ue bulks, the problem is the holes of the front skid do not line up with the holes on the rear bulk. Regular skids have the same hole pattern for the front skid as they do the back. The ue's are different so when you go to put the front skid on the rear bulk they dont line up. And to make things worse they are close enough that if you try to drill another set of holes they will overlap with the existing holes. You are better off taking a regular front skid and modifying it (larger countersinked holes and narrowing the area between the arms).
Never fight an ugly man..... he has nothing to loose
