thesteve
08.26.2006, 12:32 PM
Originally Posted by GriffinRU
And this story about FET's and high voltage based on?
And do not blame fet's control if you not sure how it works...
Artur
Based on education and several years experience working with, repairing and designing speed controls that use mosfets. And anyone thats knows basic mosfet operation would also know...
jhautz
jhautz's Avatar
08.26.2006, 07:30 PM
I'm looking at this thing trying to think of how to get more heat out of it. Adding additional mass to the bottom seems to make a huge differeance in disapating the heat. But thats only taking heat off of the bottom layer of fets. I'm thinking that opening this thing up and adding somethiing to the sides of the heat spreader to help pull the heat out of the middle of this thing could be the ultimate way to heatsink it.
Do the sides of the heats spreader contact the aluminum sides of the case?
This is really interesting to see how its set up inside. I have been wanting to tear mine open, but didnt want to void my warranty.
Cartwheels, If you open it again can you get some pictures of the top board also? Anyone know what part of this thing is the BEC?
to make it...
or break it...
Silent...But Deadly
GriffinRU
08.26.2006, 08:52 PM
Well, then any good (Quark is good) pump-charge based (not fixed 12V) fet driver has a feedback, which helps to set the voltage at level which guaranties FET's turning on and FET's safety (not to exceed GS voltage) and as well fast transition and...
Based on this your previous guess is wrong!
And any comments on Leroy's question as a professional?
Artur
