squeeforever
squeeforever's Avatar
08.28.2006, 04:56 PM
JThiessen, the reason the rear looks the way it does is because you have your upper arms in the lower position. If you put them in the upper position the rear will have a more relaxed feel and should handle better as well as fix the funny looking upper arms. Look at the bottom when looking at how low it should sit. The bottom arms should be level.
JThiessen
JThiessen's Avatar
08.28.2006, 06:12 PM
Squee: I never even thought of looking at that, for some reason I assumed I put them in in the correct spot! I get that switched and see how it handles.
I do have to reprogram my controller. When I let off of the throttle, it will do a forward flip! So that means I have interpret more Ukranian English!
