Cartwheels
09.24.2006, 02:20 AM
I have a temp-gun. It's one of those small Dura Trax ones.
I did run the Quark today. My setup has changed from what it was. I'm now using a Neu 1515 1Y. Batteries are the same, 4s 7400mah lipo and gearing is 12/51. Before I was using a 540c 9L and I always had trouble with temps creeping up to 200*F and above towards the end of the run.
Look Mom No Fans!!!
Today went good with the Quark. It never thermaled on me even without fans. It does have a pretty good heatsink mounted on it with the front windshield completely cut out for air circulation. Temps stayed in the 125* range for a good portion of the run. It was pretty much all out non stop going for approx 20 min or more except for a couple of temp checks. Towards the end the temp did get up to about 147*, but it never thermaled. The motor was at 159* at the end. The outdoor temps were much cooler then a month ago when I started this thread. It was a nice 88* day.
One of the most notable things was the temps at the boards where the motor wires come out. In the past that area was generally 15-20* hotter than the heatsink. This time those temps were only 1-3* difference and they would even out within a minute or two. To me that was pretty significant. It tells me that the work I did may actually cool the internals better and more quickly.
Quark vs. Mamba
The Quark felt like it had a higher top speed. The Mamba felt like it need to go up a tooth. Punch seemed equal. Quark overall had a more powerful feel while the Mamba felt a littler smaller. Don't get me wrong though I love the Mamba, but for 1/8 if you can get the Quark not to thermal I think it is a little more suited.
In the end I think I may still have to run a fan on the ESC, but I'm going to push it and see what happens without a fan first.
09.24.2006, 03:29 AM
Sounds like your work on the Quark paid off! If mine starts thermaling, I'll take it apart and do something like what you did since I'm sure the heatpads will have come unstuck as well.
