Cartwheels
09.26.2006, 11:25 PM
Originally Posted by smhertzog
Sounds like you may have got something there, I'm just wondering how much of the heat drop can be due to the neu motor. That and the ambient outside temperature make a big difference. I just noticed mine is loose and am going to do some changes. The shrink wrap on my caps looks like it got hot and came off, they read 35v 330uf . Im also wondering if the fact that only one bank of the fets is connected to a heatsink that sees airflow has anything to do with the overheating.
There is an aluminum heatsink on the inside row of fets but, your right the outside bank is the only one that sees airflow. No doubt the motor does help but I can tell that now that the fets are better attached to the heatsink the internals cool much quicker.
When you say that you are going to make some changes are you going to do something like what I did or something else?
scyan
Hey, thats a hyper 7 i see there ? What size pinion/ spur are you running on that ? Do you have the spyder or normal center diff ? Plastic or metal spur ?
and last one, any fan on those heatsinks ?
Thanks !
Scy
I'm using a 12/51 pinion/spur on the normal diff. Mike (RC Monster) made an adapter that fits the diff to the spur for me. The spur is plastic and holds up quite well. I don't have a fan on there but, I have the front windshield cut out completely which provides some air through the heatsink. I would put a fan on there too but I can't keep the fans from breaking so, unless I have to have one I will go without for awhile. I was really happy with the way it was running the other day.
