Serum
Serum's Avatar
10.01.2006, 10:35 AM
1950/10 is too hot. 55amps is nothing for a car. (remember, even the mamba-max controlers are for 1/10th vehicles and can do 100A continues.
but with 8s lipo the 1950/10 is still around 40000 rpm.
bottom line;
your theory is okay, the more volts the less current is needed to get a certain amount of power.
The maxximum power of the setup on 8s would be 1628watts, while a 9920 on 6S can deliver 2200 watts.
if you want to go with that controller i would look into a 700-750kv motor.
with the current setup you are planning on gearing it for 56 mph.
